jnsumanth99
Newbie level 3
Will there be any issues of using data signal for a clock port of a flipflop in a design ?
Doesn't sound like a meaningful timing specification. The important point is how the "data clock" edge is related to your design clock. If it's unrelated or potentially causing setup/hold violations, the FF output needs to be synchronized. If you can be sure that the FF output is never sampled near to the data clock edge, just cut the timing path. In any case, STA expects a clock definition for the data clock.I have a requirement of detecting the edge of my data signal. After detection, I never use that logic until a particular command is received.
Thanks for your time.
For that purpose can I use that logic ? If yes, will it cause any STA violations ?
