knowledge_Seeker1
Newbie level 6
Hello,
In the NS3 tutorial :
They set the DataRate of the NetDevice (or the NIC ) to be 5Mps,
They set the Delay of the Channel to be 2ms,
Question 1
So Data Rate is the Nb of bits a DEVICE puts on a Channel per unit of time ?
In our example, the NIC puts 5 bits every second on a channel. Is that correct ?
But isn't the Data Rate a property of the Channel and NOT the device ?
Question 2
However, here is the definition of the Transmission Delay from Google:
How could they specify in ADVANCE, what is the Transmission Delay of the Channel ?
I hope somebody helps clarifying these for me.
pointToPoint.SetDeviceAttribute ("DataRate", StringValue ("5Mbps"));
pointToPoint.SetChannelAttribute ("Delay", StringValue ("2ms"));
Question 1
HTML:
[I]Data Rate Definition from Google:[/I] The number of bits transmitted per unit of time through the physical medium.
I want to make sure I got this right.
Question 2
HTML:
In the Tutorial, they say that : the 2ms delay is the value of the transmission delay of every point to point channel it subsequently creates.
HTML:
Transmission Delay, the time it takes to transmit a message. It is the size of the message in bits divided by the data rate (measured in bps) of the channel over which the transmission takes place.
