Data exceeds memory
Hazieqbento
Newbie
Newbie level 1
C:
#include <OneSheeld.h>
char* gps = "gps";
char* stopp = "stop";
float lat ;
float lon ;
int lock = 12;
char charlat [12];
char charlon [12];
char readings [80];
boolean flag1 = false;
boolean flag2 = false;
boolean flag3 = false;
void setup()
  OneSheeld.begin();
  pinMode(lock,OUTPUT);
void loop() {
  if(abs(AccelerometerSensor.getY()) > 1.5 )
    if(!flag1)
      SMS.send("01004078579","The car is moving !!");
      flag1 = true;
   if(!strcmp(SMS.getSms(),stopp))
    if(!flag2)
      digitalWrite(lock,HIGH);
      flag2 = true;
  if(!strcmp(SMS.getSms(),gps))
    if(!flag3)
      lat = GPS.getLatitude();
      lon = GPS.getLongitude();
      dtostrf(lat, 11, 7, charlat);
      dtostrf(lon, 11, 7, charlon);
      strcat(readings,"latitude is : ");
      strcat (readings,charlat);
      strcat(readings,"\nLongitude is : ");
      strcat (readings,charlon);
      SMS.send("01004078579",readings);
      flag3 = true;
[code tags added by moderator]
I don´t even see a descripton of the proplem, nor do I see a clear question.
Klaus
Is
char readings [80];
declared too small for total worst case length needed ?
Regards, Dana.
Hello!
A few hints for asking a question:
- Some basic politeness could help (for instance, say hello, please, thanks, etc).
- Describe what you want to do and where you are stuck.
For example which data exceeds which memory would help.
Best regards,
Dora.
