dat transfer using xbee module in transparent mode
nileshgupta
Newbie level 6
Newbie level 6
i want two transmit data between two pc's using xbee module
I have configured the two xbees by setting their pan id same and setting their my address,dl address and sl address
i am using the module in transparent mode
the module which is connected to pc can identify the another module by using the command ATND
now i want to send data to the remote module through the module connected to pc
now how should i do that
xbee module is connected to pc through serial port and i am using the software xctu provided by xbee manufaturers
i have used the function in xctu to frame and send the data but i am not able to receive the data from other remote xbee(remote xbee is connected to hyper terminal of another pc) on to hyper terinal of another pc so how could i ensure that data has been transmitted from one xbee to another
There is a recent thread about the same argument, have a look at the forum index.
Anyway, you can do these checks:
1) if you are using Zigbee firmware, be sure that the network is operative. You need one coordinator and one router or end device. Check the AI parameter to see the network status
2) be also sure to use AT firmware and not API firmware
3) if you are using other firmware such as Digimesh or 802.15.4, be sure again that you are in AT mode and not API
