steviec7
Newbie level 2
Hello Everyone!!
I wanted to try and build a test source for checking Current Transformer accuracy (CTs).
I therefore need to be able to provide a variable AC current 0-5Amps were the load would just be wire passed through the CT so ~0.01ohm. The voltage would be vey low as the resistance is so low. The easiest way to achieve this is to use a variac on the primary side of AC supply but I want to do it another way.
If I used PWM & MOSFET Bridge supplied from a DC source would this be able to give me a good current resolution/accuracy. I've seen the Class D amplifiers, with a 50Hz signal produce X watts through say 4 or 8 ohm but can these systems handle such a small resistance load as 0.01ohm and still provide an accurate variable puresinewave current waveform? :-?
Many thanks in advance for any helpful information
