Cyclone M4K RAM blocks and clock enables
cyr
Member level 2
Member level 2
Sweden
area26.no-ip.org
m4k ram
I'm trying to implement a simple instruction cache for a small CPU, inside an Altera Cyclone FPGA. I'm using M4K blockrams in "simple dual-port" mode, with separate read and write clocks (actually the same clock, but separate clock enables). The read port is connected to the CPU and the write port connected to the external bus. I *dont* use registers on the data outputs.
When there is a cache miss I want to stall the CPU pipeline, including the read side of the block ram (I need to save the current adress) - so I use my "cache hit" signal as a clock enable. The problem is that after the new data and tag has been written into the rams, the old data still remains on the output side. Like I said, I *dont* have any output registers so I expected the new data to flow right through, but nothing new comes out until I force the clock enable for the read port high.
Am I being stupid, or is there a bug in the simulation models, or does the M4K block RAM really behave like this?
If I'm not mistaken, there is a page in the MegaWizard generator that deals with this kind of behaviour. You may want to check that to find a setting more to your liking or at least get a bit of info.
