radium98
Full Member level 2
Hello ,and i hope you are in a safe place ,from covid19 away taking precautions.
i have a problem and i dont know if i post in error section,because i dont where should i post this thread please correct it at admin.
i have searched before posting to see if it ia a problem of me .
I have recently boring and built the cw ik3oil decoder, i have found many hex files,none work ,programming sucesful.even i get the correct one from author he sssaid 16x1 the lcd i have,but i read that it is 16x2 i am confused ,i always have 8 dots on lcd,i have doubt in connections could youclarify if the 4th pin ground go to RW a possible given reconnection wiring is good
thanks
vcc
vo
gnd
4 ? the ground pin to where ?
5 to RS
6 to E
i added my construction pictures and the original hex from author he said 16x1 but i see 16x2
where in asm i can change the name ?
and please see the connection wiring if any error ,so why i have 8 dots while hex burn succesful
thanks
thanks
vcc
vo
gnd
5 to RS
6 to E
thanks
