[SOLVED] Custom Toroidal Transformer
wmingin
Newbie
Newbie level 3
Hello All...
I require a custom Toroidal transformer for an experiment...
Frequency 60 Hz
input: 18Vac / 100 watts
Output: 2,450Vac / 200 mW
Can I just purchase any 100 watt Toroidal and rewind it to 136:1 ( assuming the windings fit? )
Thanks,
Bill
( Dont worry, I'm familiar with high voltage precautions )
No that won't work. Do you know how to compute/simulate your primary peak current with no load vs L1:L2?
The turns ratio is far too high for 1:136
You might want to look at a flyback boost circuit.
Thanks for the reply.
No, I haven't researched that far.
I was hoping for the easy ( lazy🤪 ) solution.
I did notice that blank cores can cost more than completed transformers,
and are harder to source.
I apologise for my ignorance.
Best regards,
Bill
Your power specification (100 W pri/200 mW sec) makes no sense. I wonder how you got there? Making a 50/60 Hz transformer with kV secondary voltage is possible of course, but toroidal design is least favourable for high voltage, I believe. I would rather expect a standard M or EI core shape. Consider proper winding insulation to handle the voltage.
We don't know the application, if it's constrained to a low frequency transformer and AC output?
You sound angry.
Sorry for the confusion.
I really don't know much about transformers other than choosing off the shelf models that fulfill my voltage and current requirements.
What i meant was I have a 18vac 5.5 amp supply, and I need approx 2400 volts @ approx 100 ma
If I have to learn transformer design to get there, I will.
Please don't be offended.
We all have to start somewhere.
Thanks for the replies.
Goodbye.
what you can do is get hold of a few 12V to 230V small transformers, say
11 in this case, you can then run the 12V wdgs from a variac, in series you need a variac that goes to 130Vac, the outputs of the small transformers can be series aiding connected to get 11 x 230 Vac = 2530 max no load - be careful
You sound angry.
Goodbye.
He is not angry. But you must correct errors.
Your #1 Q says Output: 2,450Vac / 200 mW
Now you say 2400 volts ... 100 mA = 2.4 kW
But you must let us know if you made a typo error or are changing requirements which ought to include purpose.
For low power HV I suggested an autotransformer.
For DIY HV with more power search for MOT HV on youtube (microwave oven transformer , rewired.) Do it yourself (DIY)
Write your reply...
LaTeX Commands Quick-Menu:
