[SOLVED] Custom Design post layout failed
Marsana
Newbie
Newbie level 1
Hello, I'm trying to post layout Full adder 1 bit in Custom Design but I have an error:
"Terminal vdd! found in starrc is missing in symbol"
"Terminal gnd! found in starrc is missing in symbol"
and:
Warning: "Terminal D found in hspice is missing in ivpcell" (NETLISTING-003)
Warning: "Terminal G found in hspice is missing in ivpcell" (NETLISTING-003)
Warning: "Terminal S found in hspice is missing in ivpcell" (NETLISTING-003)
Warning: "Terminal B found in hspice is missing in ivpcell" (NETLISTING-003)
When I check in netlist, GND and VDD not there
I don't know how to fix it, please someone help me
That's peculiar because vdd! and gnd! are global nets which
require no pin on a symbol.
Maybe the error doesn't mean what you think it means. Like,
is it telling you about "is wrong" or is it telling you about
"should have been right"?
Start with the symbol that's supposedly "missing pins" for the
global nets. What -is- there, and what might be net-name
"fumbles" as you go up and down levels of hierarchy - and,
too, discrepancies between view-types (maybe you are using
a stale view that nobody's maintained in a decade, and its pin
list is not the same as what you switched from / to).
But I do not recognize this specific tool, and there could be
other things at play (like "vdd!" not representing a global, in
this tool's dialect, or needing it declared so).
