current vs time graph in cadence ADE L
muffassir
Member level 3
Planet Earth
hi all,
I am designing current mirror in cadence using ADE L...
the input is current of 10u A .i want this current to be mirrored at the output.
But when i am doing AC analyses i found that the y axis is in volts.I want to plot input and output in current vs time axes for both .
So that i can see my input current being mirrored at output .i.e i expect to see current of -10uA at output.
I am newbie please explain in detail how to do it...
Thanks in advance.!
For plotting don't select the output node (wire), but the output pin of your current mirror (probably its drain), or the input pin of the mirror load. After selection, a small oval mark should appear over the selected pin. Then you can plot the current into this pin.
First of all if X-axis has to be time, then perform transient analysis (not ac analysis). Probe the node (drain of MOS), and not the net. You might be probing the net hence output is in voltage.
