FreshmanNewbie
Advanced Member level 1
I was just going through the purpose of the Current transformer and its working & using.
I found some schematics where I found a common pattern as below. It is a single-phase connection. LINE & NEUTRAL is the input of a single-phase supply.
The LINE CURRENT & NEUTRAL CURRENT connectors are connected to a Current transformer.
The outputs I2P/I2N & IP/IN go as inputs to an energy-metering IC.
Can someone tell me what are the purpose of the Resistors and capacitors in the above circuits and how the values are selected?
Also, I'm not able to understand the purpose of the LINE to VP connection.
I searched about the type of connections, but was unable to find it.
Any idea/guidance on this would be greatly helpful.
