syamin0712
Member level 1
What I understand about I to V converter using op Amp is that the output voltage will equal to the resistor x current input that we have.
Something like this figure:
https://obrazki.elektroda.pl/1069454400_1442453480.png
So that the output voltage will be
Vout = -IsxRL
However,
when I simulated the circuit; in my case the current input is 2.5mA with operating frequency is 2MHz, and I'm using LT6200CS8-5 as my op amp.
https://obrazki.elektroda.pl/3328319100_1442453788.png
Noticed that, the 1k ohm resistor and 4.7pF capacitor are to stabilize the circuit only.So that, the current value is maintain.
If using the above equation; Vout= -2.5mA x 1.2kohm =-3 Vp-p
The output value was not same as the equation above. The Vp-p is around 8.64 Vp-p.
Could anybody explain it to me what is the error and how to solve it.
Or that equation will get the output in RMS value?
Thank you in advanced.
Vout = -IsxRL
However,
