Adraen
Newbie level 5
So, I would like to measure the current drawn by a 5V line with a maximum draw of 750ma, the other requirement is to be able to switch on/off the line.
The original idea was to use a N-channel mosfet on the low-side for on/off, and use a shunt with an op-amp on the high-side, but i've been thinking if I could do anything smarter ....
What i'm thinking is to use a p-channel mosfet on the high-side and use the Ron resistance of the mosfet as the shunt resistor and use something like ZXCT1009 to monitor the drop accross the shunt. I'm not sure if that would work though, from your experience do you think the mosfet resistance is accurate enough to use as a shunt ?
I might do this the wrong way though there might be some IC that do switching/monitor at the same time but I wasn't able to find one.
Anyway, would you have some ideas on how to go about doing something like this ?
Thanks
Thanks
