Spoerle
Junior Member level 2
I am rebuilding a machine standing outside.
The power supply will be via 400V (motor 4kW) control electronics over transformer 400V/2x12V 16VA.
One 12V winding is rectified and used to power the MCU.
This voltage also powers the signaling LED.
10mm RGB LED, 20 mA, common +.
Signaling LEDs switch contactor, relays and MCUs via transistors.
The question is whether and how to solve the source for the LED
1. Nothing special, + on 16V DC and limit the current with a resistor to approx. 17 mA. Pros very simple
2. A simple 20mA current source with a resistor and two NPN transistors. Cons complexity of a total of 4 components for every color in LED RGB
3. Current source with LM317LZ and resistor. Cons Price
4. Something else?
Thanks
4. Something else?
Thanks
