current sensor placement
yassin.kraouch
Advanced Member level 2
i have to use the asc 758 current sensor to measure the current of a series battery, the problem is that i don't like to place this sensor directly on the PCB, i would like to place the sensor on the copper barrette binding battery, have you an idea on how to do this ??
Mechanical structure can be with or without shunt resistance
If the device can handle maximum current in circuit ,
there is no need for shunt resistor.
I drew a principle picture for you.....................
View attachment Hall_current_sensor_in_rail_01.pdf
Added knowledge............................
Regards KAK
