T
treez
Hello,
The CSM3637 current sense resistor has different size pads depending on the resistance value.
The lower resistance values have much wider pads.
CSM series datasheet:
http://www.vishaypg.com/docs/63089/csm.pdf
Our prototype boards need to be able to have either the low resistance version or the higher resistance version.
Therefore, do you think it will be ok to just use the "wide-pad" land pattern, and fit the "narrow-pad" resistor to this "wide-pad" footprint in those cases where we do use the higher resitance values?
