Current sense coil number 2...
Externet
Advanced Member level 2
Mideast US
Hi.
If a wire conducting 1 Ampere of alternating current passes inside this 1000 turns coil; will an AC voltage show up at the coil terminals ?
Yup it will. But it depends on coupling factor as well. Generally for current sense, primary conductor is also wound for a single turn over the coil to give a better coupling factor.
