anselm
Newbie level 1
Hello!
I just registered.
I am not specifically electronic trained, but I have some hobbyist notions.
I am trying to create an adjustable current regulated power supply.
Requirements:
Input: 3-4V DC (more specifically, a single LiIon cell, 18650)
Output: 3-7V DC @ a maximum of 1.5~2 Amperes.
constant current, Adjustable via potentiometer or selectable via jumpered resistor, for example.
At first, breadboard sizes are OK, but if the design is sound, a small PCB version
would be awesome.
Can someone "shove" me in the right direction?
I am still not even sure wether I should make one from scratch using diodes, transistors, caps and an inductor coil, or use one of the many boosting PWM switching ICs.
Precise output voltage is not as important as a solid current regulation.
Any help will be greatly appreciated.
I just registered.
Requirements:
would be awesome.
