Current reference help
copoler
Member level 1
Member level 1
If i have got a reference voltage,how can i get a constant current independant of corners and temp?
Thank u!
Having reference voltage you can generate current as in the attached circuit (one branch required)..
    copoler
Dear Ianp:
Thank you at first!
I'm still have some query about this circuit.
The resistants-RE will change a lot when temp rise,so IC=VIN/RE will change too,how can i keep IC constant?
Regards!
copoler
Dear Copoler,
Is it possible you could replace that Re by switch cap n/w. Capaciors are prone less to corner and parameter variation.
Else you need to use some other configuration, or take Re offchip and use a precesion resistor
    copoler
