Current mirror image: why M1 has to be diode connected ?
robeleon1
Newbie level 2
Newbie level 2
current mirror
why is necessary that M1 be diode conected?
Re: curren mirror
It works as a resistor, so if a current flows through it, a voltage is generated. This voltage is applied to the other MOS gate and another current is generated.
You can obtain a desired current by changing the sizes of the transistors.
See Design of Analog CMOS ICs (Razavi).
Re: current mirror
ok STOIKOV,
if i don't connect the gate with the drain of M1, a current that flows through M1 is not going to generate a gate voltage?
Re: current mirror
In my opinion, the requirement of current mirror is that.... both vgs has to be same
so to get the precise same gate voltge they always connected together... but on the other hand both FET have to be in saturation mode...
so the drain and gate voltage same is best configuration so far for the saturation
and it's also easy to deal with is
cause for the saturation
vds >= vgs -vth
so if vds and vgs are same then vds will always more than vgs-vth
and don't think FET connection can make diode. BJT transistor ... u can think of diode... not MOSFET
