jutek
Full Member level 4
hello
i'm working on attached circuit. it enhances slew rate of amplifier.
could you tell me what's the role of the current mirror in the amplifier?
it converts differential output to single-ended and allows to achieve higher gain in one stage opamp. what else?
what if i don't want to use this current mirror cause it makes amplifier's output resistance high and deteriorates bandwidth. the opamp has two outputs without thic current mirror and i need one. when i use simple single-ended ota how should i connect slew rate enhancement circuit on the right side then?
regards
regards
