stoyanoff
Full Member level 4
Greetings! I`m trying to make a current loop. Here is my schematicView attachment current loop.pdf
When I connected it through the another node(I`ll call it "slave" and my node should be "master"), I`m receiving my data correctly. As you can see the current loop is pumping pulses on both receivers. The 6n136 is fast enough and there is no delay, the baud rate is correct. I`m using UART with invert polarity set on TX and RX, because 6n136 inverts data! The problem is the slave doesn`t respond... When I use a market device it`s working, but my circuit doesn`t fit.. Any ideas?
PP: Baud rate and UART settings are correct!
