[QUOTE][/QUOTE]
Analog meter has a current shunt. Often the movement is a 10K/V sensitivity and the shunt is limiting current. Anyway, you need to read the fine manual that came with it. DMM also has a current shunt but the value is much lower.
You did not say how much voltage you applied. If the applied voltage is like 5-10V, the case is fully understandable.
Liquid bleach is an undefined material. Better to use solutions of known chemicals.
I thought maybe the meter resistance had something to do with it but I can't understand why...
When I place cell in this liquid there is a strong reaction at aluminum plate which forms gas bubbles. The odd thing is when I start drawing current the reaction slows down drastically. Anyone have and explanation for this.
The alkali (sodium hydroxide) removes the protective oxide layer from the Al surface. It also attacks the metal with production of Hydrogen. The gas bubbles you see are hydrogen formed by oxidation of the Al.
When you start drawing current, the reaction does not slow down. But it may appear (incorrectly) that the hydrogen evolution has considerably reduced. The fact is that the hydrogen ions are now pushed toward the copper plate.
What other gas could be produced in this reaction. I don't think that hydrogen gas would make you cough and burn your nose....
In post #9 you stated that hydrogen is released from Aluminum plate. I must be misunderstanding something.
I have been attempting to make a rechargeable cell using aluminum and graphite material.
