engr_joni_ee
Advanced Member level 3
Hi, I have seen de-coupling capacitors in the power rails in micro-electronics PCB. Normally there are 0603 SMD packages which I guess perform better and low ESR at higher frequencies. I have seen their voltage rating and capacitance as main selection parameters for examples 100 nF 35 V SMD 0603 capacitor. How about the current consideration if they are used in the power supplies having 12 V for example that is supposed to deliver 1 Amp.
I mean do I only need to select de-coupling capacitors with their capacitance and voltage rating regardless of which current is the power rail is delivering ?
