Only if they are spaced wide apart. There are plenty of online current carrying calculators which will give the correct width against IPC rules.
Keith
Yes, You can split the track width (1/2) to both side of the PCB for the same current.How wide apart Typically?
I am making a very simple board, it has two through hole screw type terminal connectors. They are spaced 25mm apart and the traces are run straight through. I need the traces to carry 14 amps @24VDC.
I downloaded the Saturn calculator suggested in the post below. Using the Conductor Properties Tab and the Solving for Conductor width with a know length of 25mm and 14 amps with 1oz. copper board. I get a conductor width of 9.84mm. Now if I run traces back to back, 1 on each side of the board can I make each trace 4.92mm?
