celebrevida
Member level 2
I am trying to design a CTAT voltage generator such that:
Vout = mx + b
where I can control both m and b separately.
The closest I can come up with is using the CTAT voltage of a bandgap reference circuit.
If R2 is actually several transistors in series, then I can select different taps "inside" R2 using an analog mux and thus select slope "m".
And we can see that:
As I select the slope "m", I am also changing "b" at the same time!
How can I design a CTAT voltage reference in which both "m" and "b" are independently selectable?
Thanks for any help!
Vout = mx + b
- Node (a) would have the most negative slope (m_maxneg)
- Node Vref would have a flat slope. (m_0)
- All nodes between Vref and a would have a slope between m_0 and (m_maxneg).
