barnaby.hill
Newbie level 1
I am working on a university project and I want to measure current through a cable. I want to view this data remotely and there wont be WiFi connectivity. So I assume the best solution is to use a Ct clamp and a data logger which is capable of sending data by using mobile data from a sim card?
I don't need to view live stream of the data but just a daily report of power used each hour.
I need to measure power up to 4kW at 240v so maximum current of 17A.
Is there a single solution that can achieve this, or do I need separate data logger and CT clamp.
I know a raspberry pi could do this for very cheap but i want as close to a plug and play solution as possible as i don't have much time.
Total budget would be max £50
Thanks a lot
Thanks a lot
