CSV exporting in Cadence Virtuoso
unix_amr
Junior Member level 1
Hi all
I simulate one flip-flop via IC 6.17 with 1000 Monte-Carlo iterations in ADEXL. After finishing, I select all of 1000 output voltages plots to be shown in result browser. The next step is selecting all curves (traces) in result browser and exporting as csv file. Astonishingly, after opening csv file in excel, I see only 829 columns associated to the output voltage. Where are 171 other columns? Any ideas?
Any help is appreciated.
Thanks
Hi all
Usually that happens when you export a bunch of data in CVS in Cadence. This is a bug I guess that they need to fix. One way to verify this, is to identify which one is missing, and if you are able to export those individually with its correspondent CVS file, then is just not taking all the data. Another option is to pick less data at a time.
Thanks, I failed to export missed plots individually because this plot option is disabled. This is an annoying bug in cadence virtuoso adexl.
