nadabro
Member level 4
Hi. I´m doing a work about Waveguide slotted 2.4ghz antenna but when i simulate the slotted waveguide (using waveguide port) using a slotted PEC bigger than 300mm, the results are very innacurate (S-dB/farfield/etc), but if the slotted have less than 300mm everything works well. the first issue that i know that something is wrong, is the information about the "number´s processor in use 0", if is <300mm always says 1.
since i dont have CST at home (only in my university)..i have very few time simulation available, if anyone can see the antenna feeding or mesh properties i´ll appreciate.
Thanks.
Thanks.
