Ludovic_29
Newbie level 5
Hello,
I would like to know if there is a possibility to use a voltage monitor results (Voltage over frequency) from a 3D simulation as a voltage source in a schematic simulation in CST ?
Is there a described process somewhere that explains how it can be done ?
I can export datas from voltage monitor results but I haven't found the way to add it to excitation signal for a schematic simulation.
Thank you,
Ludovic.
Thank you,
Ludovic.
