[SOLVED] CST Studio Microstrip Monopole Antenna Simulation
Radike
Member level 3
Member level 3
Hi All,
I am trying to simulate a Bluetooth Microstrip monopole antenna in CST studio. The design was taken from Nordic Semiconductor's nRF52840 dongle (https://www.nordicsemi.com/Software-and-tools/Development-Kits/nRF52840-Dongle) reference design.
Please see below a image of the PCB. It does not have a ground plane underneath.
Above image is taken from the reference design given by Nordic Semiconductors. I am now trying to simulate the above antenna in CST Microwave studio.
In the above image circuitry from the green arrow to the right is the matching circuit to the chip. I wanted to simulate the antenna to the left of the green arrow and then include the matching circuit first.
Substrate details are as follows (Actual fabricated dimensions):
FR-4 - Dielectric 4.8
h = 78.74 mil
Antenna microstrip trace width, w = 10 mil
I have modeled the above circuitry (Antenna to the left of the green arrow) in CST Microwave studio. Please see the attached image below.
My questions are as follows:
1. How can I assign ports to a such a monopole antenna in CST?
2. Should I use a Waveguide port or a discrete port. In this case I don't have a ground.
3. I tried to use CST Maxros->Ports-> Calculate port extension coefficient and gets the following massage.
4. I manually created a waveguide port with the following dimensions:
waveguide width = 7*w
waveguide hight = 6*h
But the results were very bad. Please see the images below. Because of the w/h dimensions, port looks wired. But these are the actual widths and heights
they have used in the design.
Is it possible to know the correct way of simulating such an antenna?
The antenna is incomplete, a monopole can't work without a ground plane, in this case right of the feed point. The discrete port will be connected between the ground plane and the feed point.
Reactions: Radike
    Radike
Hi FvM,
Many thanks for the reply.
Should I draw a separate ground plane to the right of the current feeding point?
Or the ground should be defined in the discrete port? I get the following box when I select the discrete port.
What X1,Y1,Z1 and X2,Y2,Z2?
In the nRF dongle, RF feeder line width is 35 mil which I think had calculated as a CPW. So I added a feeding CPW Microstrip line to the antenna with width 35 mil. Now I am getting some what sensible result, but the return loss is still not very good yet.
Below please see the images of the new port configuration and the results. Any idea what I am doing wrong. I am also getting some warnings while running the simulation.
I have simulated and designed many of these PCB antennas for clients.
It is absolutely critical and important to include the true PCB ground size, which acts as an integral part of the antenna. Your model will not give useful results with the small pro-forma ground that you show. Model PCB ground in real size. The port type isn't critical, you can use a lumped port.
Reactions: Radike
    Radike
Hi Volker,
What I wanted is to do a simulation on just the antenna section and then add separate lumped element matching network so that I can match with the impedance of the nRF chip ANT port. Is it ok to add the entire ground plane and then add matching network separately?
I have attached an image of the actual top layer and bottom(Blue - Ground) layer PCB design.
As you can see, the blue color ground plane is not completely a plane. In this case should I draw a one big ground plane with the same size as the circuit?
I am also bit not clear on applying discrete port positive and negative port pin definitions. Based on the impedance calculation, the RF feeder width is calculate as considering it as a CPW. However, I do also get a ground plane underneath of this line. In this case should I also select this plane as a negative port pin as well?
Removing the bottom ground plane in my above simulation gave me a 9dB return loss. But this won't be same as the actual as there is a ground plane below .
The question was about antenna simulation which needs 3D full wave solver. As volker explained, you should model the actual ground plane dimensions, I'd suggest as a rectangle.
Although the plane is has some voids, it's still mostly continuous. Outcome of the simulation is the antenna impedance at the feed point and optionally its radiation characteristic.
I assume that the coplanar line with ground doesn't significantly couple to the free field and can be simulated separately with more simple tools, if necessary at all.
Things are a bit more complicated if additional conducting planes and cables are connected to the ground plane and thus become part of the antenna.
Reactions: Radike
    Radike
Hi FvM,
Thanks for the information. I tried simulating with the actual ground plane size. One with CPW feeder and another without CPW feeder.
Result were really bad when I did not include the CPW feeder.
With CPW its much better. I created a larger waveguide port with height about 5*h starting from the bottom ground plane and width 2*feeder width. Changing the waveguide port width to 3*feeder width shifted the curve to the right. I am not sure why this is so. Let me know your thoughts, suggestions on this.
Should I always include such a 50 Ohm feeder when I simulate Antennas?
In the actual PCB, there is 1.5pF capacitor just at the feeding point I am not sure how to include that. Any suggestion on how I can include this or what would you recommend?
Thanks a lot
    landho
Yes, you can simulate the antenna with an (approximate) simplified PCB ground.
The port is then connected between the antenna feed and that ground. Indeed, matching can be done later using that 1-port S-parameter result from EM.
Yes, I think you can do that simplification and make it a large rectangle. Your PCB ground is reasonably solid near the antenna, that is the most critical part.
In the final verification, I usually simulate with full PCB layout detail, but that is not a must.
Your PCB seems to be a module. What I do in these cases: include the motherboard where the RF module is mounted onto. It does make a difference in some cases.
I don't know CST port handing details. In general, place one end of the lumped port on the antenna feed and connect the other end to nearest PCB ground.
Good luck!
Reactions: Radike
    Radike
Hi All,
Many thanks for your support.
Thanks!
I believe the approach of arbitrarily modifying the feed line or matching components isn't very systematic. Instead you would measure the antenna impedance as is and design a matching circuit in the second step. That's particularly suggested if you don't a achieve a good matching with trial-and-error method.
Hi FvM,
Based on my above simulations above, If I don't have a feeder line then I see a very poor return loss. Seems antenna impedance at the input is not matched to 50ohms. However, adding a 50 ohms CPW feeder line helped me to get a good return loss. Is this expected or there is some issue in my simulation setup?
Length of the feeder I used was 250 mils, much smaller than a quarter wave length at 2.4 GHz.
As FvM mentioned, your configuration is not recommended. The "trick" that makes your CPW feed work is not CPW itself, it is the related ground structure that comes with the CPW feed. That ground is on a different layer than the other testcase, and possibly different size. That ground is what changes your matching.
You should really use a practical port feed scheme (e.g. lumped port) and go from there. Mixing antenna ground into the feed (by making feed ground part of the antenna) will drive you crazy later when implementing the actual layout.
It seems that the original antenna design includes a series element, most likely for matching. So if you don't have 50 Ohm for the antenna itself, that my be correct.
Good luck!
Volker
PS: Below I added what my simulation models look like, using a lumped port. Then, feed and ground for the antenna is modelled in a realistic way. You can simplify, but don't add in artificial elements like a large port that doesn't exist in hardware.
Reactions: Radike
    Radike
Hi Volker,
Thanks for the reply.
So the best approach is to model the actual circuit as closed as possible to the real PCB in CST and use a lumped port at the antenna feed point and then use this simulated data to add the matching circuit?
When you say lumped port, in CST this is equivalent to Discrete Port right?
Because there is no "Lumped Port" option in CST.
Yes, lumped port = discrete port.
Simplification: only as much as it doesn't change the ground situation (ground currents) seen by the antenna. It is a trade-off if you want fast simulation in the design phase. You might want to do some test cases in the beginning, then later you have experience how much simplification is "safe".
Reactions: Radike
    Radike
    Thanks, this helped a lot.
Thanks Volker,
Appreciate the support given. I will try out and see.
