Hello
I use CST MWS in order to design and simulate TSA with a substrate of high dielectric constant (Roger duroid RT6010)
Then i don't succeed to find paper result (S11 dB) ("Compact Tapered Slot Antennas for UWB Microwave Imaging Applications ") when i simulated this antenna with CST.
I have the bandwidth but the reflexion coefficient is still over -10dB , but is the paper it is below -15dB.
Is there a special way in order to correctly simulate antenna with high dielectic constant ( mesh , accuracy)?
Thank you
