yangkk
Newbie
I want to use CST to calculate the near-field RCS. The specific example is as follows: there is a metal rod directly in front of the feed source. I need to obtain the monostatic echo signal at each step angle as the metal rod rotates 180 degrees. Can this case be realized in CST? How exactly can it be done? Thank you all for your help.
