kela3kela
Full Member level 4
Dear Members,
I am desiging a simple rectangular substrate filled waveguide in CST MWS using Si Wafer. The dimensions of the wafer are in um and the center frequency is 10 THz. I have selected the optical template in CST. I am getting following error when assigning the relevant thickness of wafer materials i.e. SiO2 (1.5 um)+Si(380 um)+SiO2(1.5 um).
Can someone kindly assist.
Error:
The settings you have chosen will lead to a mesh with more than 100 billion cells. A model of such a size is quite uncommon and we suggest to contact CST support to discuss the setup of your model.
Brick creation leads to the following bounding box problem: Dimensions are too large for the 3D Modeler.
Awaiting your positive replies,
Regards
Error:
Regards
