[CST Microwave] sensitivity analysis
uda_x
Newbie
Newbie level 2
Hi all, I am new to CST Microwave studio and wanted to know how one can do sensitivity analysis w.r.t. some design parameters of the problem. For e.g. if I had a simple patch antenna with dimensions (parameters) L and W, and I wanted to know how sensitive the dip in S_11 was w.r.t. the design parameters, how would I do this? Thanks in advance.
You could do a sweep of theses two parameters L and W.
In Simulation -> Parameter sweep -> New sequence -> New parameter -> L and W. You can place a range of different values for your sensituvuty analysis. The number of points depends on your time and your computing capacity.
Regards
Thanks. Yes, a parametric sweep would give an idea. However, a sensitivity analysis would give me the partial derivatives of an objective function of my choice, which is more quantitatively helpful. Particularly if the sensitivity analysis is done using the adjoint method, the number of function evaluations is reduced compared to finite difference techniques.
Ok, I get it now. It seems that in your "Setup Solver" you have the option of "Sensitivity analysis". Check the properties there. I hope this can help you.
A link to the manual --> https://space.mit.edu/RADIO/CST_onl...al_overview_sensitivity_analysis_overview.htm
Regards.
