prafuldeo
Full Member level 3
cst models
Dear friends,
I was comparing the time and frequency domain solver in CST MWS 2009 for the accuracy of the results and I found that the results in both of the solvers are very different. I've been reading about these solvers and everywhere they are showing nearly identical results so I am curious why my results are not matching. I use time domain solver for my antenna simulation but wanted to check the frequency domain solver too. I am using adaptive meshing technique to get the correct meshing. Reults are not same for two solvers and thats strange. I've attached with this post two cst models. One is dipole in free space and another is same dipole pierced through the dielectric slab. The total length of the dipole is 500 mm with wire radius r= 0.25 and it is fed via discrete port at 125 mm. Same dipole is pierced at 45 degrees in dielectric slab of Er = 16 with slab thickness of 100 mm . Now when I simulate the only dipole (First model) in time and frequency domain the results are different and same is happening to my second model i.e. dipole with dielectric. It will be great if someone just look at the model and suggest me where I am making a mistake and how to get the same results in both the solvers. Thank you.
Regards
Praful
Dear friends,
Regards
Praful
