bosskardo
Junior Member level 2
Probably a stupid question. What is an easy and cheap way to measure crystal oscillators? F.e. this:
https://eu.mouser.com/datasheet/2/698/REN_XL_Crystal_Oscillators_Datasheet_DST_20220302-1954959.pdf
I know it's easy with oscilloscope but would it be possible with frequency counter as it's cheaper? But then there is the problem of what kind of leads to use (as I understand, oscilloscope leads won't work?). Crystal is mounted on a board.
If using oscilloscope to measure, what kind of accuracy does it need? If frequency is 180MHz and I only need to measure the frequency (but still accuratelly), don't need the waveform to be really accurate, can I use lower bandwidht models? Like 200MHz or even 100MHz?
Thank you
Thank you
