FreshmanNewbie
Advanced Member level 1
I'm using this USB2513 hub with this 24MHz oscillator.
By mistake I had placed 1Meg resistor across the crystal. In some boards, even with the resistor, it is working and in some boards it does not.
In one non-working board, I removed the 1Meg resistor and it started to work.
I just wanted to ensure whether my crystal circuit components are fine. Below are the component details:
Edit:
Also, any idea how the Hub works even if some boards have the 1Meg resistor across the crystal?
- Oscillator: ECS Part Number ECS-240-10-36-CKM-TR; This has a specified load capacitance of 10pF and shunt capacitance of 5pF.
- C1=C2=18pF
- Trace Length from XTALIN to C1 = 0.287"
- Trace Length from XTALOUT to C2 = 0.351"
- Both XTAL traces are routed over a ground plane on the next layer down. The thickness of the prepreg is 3.4 mils.
Edit:
