Crystal Filter impedance matching ?
emax0198
Member level 2
Member level 2
crystal filter matching
For a 10.7 MHz crystal filter the input and output impedance specified by the manufacturer is 3.0kohm but the circuit requires 330ohm input/output impedence.
Now how or what kind of resistive network is required to match. Should the resistance be connected in series or parallel? I don't know the equivalent circuit of this filter.
crystal filter impedance matching
I would not recommend a resistive network for filter matching. It will increase the insertion loss.
Try an LC network.
A small software as WinSmith or RFsim99 will help you.
You can download RFsim99 from here (go to Tools/Design/Match):
10.7 crystal if filter
-try to search for circuit examples at manuf. site of filter.
- e.g. AADE filter design prog. can help you to match
- simple wideband matching by C and R are commonly better for low ripple and higher stopband
Hi
You can also use a transformer to do impeadance matching. for your case ohm ratio is 3000/330 = 9.
Regards
