So When it is trying to calculate with pessimism removal it will look into different launch edges and different capture edges and it will apply derates as per analysis. correct if i misunderstood ?STA will understand the multi cycle path, but no different computations will take place because of it. It still is a reg2reg path that must respect setup*N under different launch and capture times that may be calculated with pessimism removal.
