[SOLVED] Cross Talk vs. Coupling
chiques
Full Member level 3
Full Member level 3
California
What is the difference between:
Crosstalk
Coupling
They use different terms to address one thing in different contexts.
Reactions: chiques
    chiques
Same thing really, crosstalk is always bad.
Coupling may be something you are trying to achieve, or it too may be bad.
Reactions: chiques
    chiques
Crosstalk - one signal interfering with another
coupling - added capacitive load to a signal
Though crosstalk requires one signal to be coupled to another
coupling---connecting one module output to another module input.
(module --may be single device or a whole circuit)
(similar to the ' mechanical coupling)
crosstalk --- refers the input to a module , due to the coupling effect, but it is unwanted.
coupling --wanted --try to maximise.
crosstalk --unwanted - try to minimise.
Reactions: chiques
    chiques
