Cross compiling OpenSSH
amraldo
Egypt
openssh cross compile
AA,
Did any body succeed in cross compiling OpenSSH embedded linux?
BR,
Amr Ali.
cross compile openssh
AA,
Do you have a tutorial?
BR,
Amr Ali.
cross compiling openssh
ou can use buildroot for that: https://buildroot.uclibc.org/. Otherwise you will have to download ziplib and openssl first and build them, than you can configure openssh and build it.
Command for that is something like:
./configure \
--target=mips-linux-uclibc \
--host=mips-linux-uclibc \
--build=i386-pc-linux-gnu \
--prefix=/usr \
--exec-prefix=/usr \
--bindir=/usr/bin \
--sbindir=/usr/sbin \
--libdir=/lib \
--libexecdir=/usr/sbin \
--sysconfdir=/etc \
--datadir=/usr/share \
--localstatedir=/var \
--mandir=/usr/man \
--infodir=/usr/info \
--includedir=/opt/buildroot-20070820/build_mips_nofpu/staging_dir/usr/include \
--disable-lastlog --disable-utmp \
--disable-utmpx --disable-wtmp --disable-wtmpx \
--without-x \
--disable-nls
assuming mips is your target.
