Dude99
Newbie level 2
Recently downloaded a memory model for DDR4 memory from micron's website and found that they have converted their models into System Verilog Interfaces.
I'm ok with that... however, I still need to put a wrapper around it to make it work with mixed VHDL/Verilog-2001 simulation. I'm not really sure how to correctly connect the inout ports from the system Verilog interface to the inout port on the Verilog module. (see below)
Here's the interface connected to the system Verilog model from micron:
Nice of them not to include any modports in the system Verilog interface to specify the port directions... well... we all known DDR has a few inouts from the specification for DDR4 memories...
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 // blasting the system interface because Verilog and VHDL doesn't support them... module ddr4_module_wrapper( input logic[1:0] CK, input logic ACT_n, input logic RAS_n_A16, input logic CAS_n_A15, input logic WE_n_A14, input logic ALERT_n, input logic PARITY, input logic RESET_n, input logic TEN, input logic CS_n, input logic CKE, input logic ODT, input logic[MAX_RANK_BITS-1:0] C, input logic[MAX_BANK_GROUP_BITS-1:0] BG, input logic[MAX_BANK_BITS-1:0] BA, input logic[13:0] ADDR, input logic ADDR_17, input wire[CONFIGURED_DM_BITS-1:0] DM_n, inout wire[CONFIGURED_DQ_BITS-1:0] DQ, inout wire[CONFIGURED_DQS_BITS-1:0] DQS_t, inout wire[CONFIGURED_DQS_BITS-1:0] DQS_c, input logic ZQ, input logic PWR, input logic VREF_CA, input logic VREF_DQ, ); parameter int CONFIGURED_DQ_BITS = 16; parameter int CONFIGURED_RANKS = 1; parameter UTYPE_density CONFIGURED_DENSITY = _4G; DDR4_if #(.CONFIGURED_DQ_BITS(CONFIGURED_DQ_BITS)) iDDR4(); //micron's ddr4 system Verilog model ddr4_model #( .CONFIGURED_DQ_BITS (CONFIGURED_DQ_BITS), .CONFIGURED_DENSITY (CONFIGURED_DENSITY), .CONFIGURED_RANKS (CONFIGURED_RANKS) ) ddr4_model ( .model_enable (1'b1), .iDDR4 (ddr4) // here we have a single interface for ddr4 ports ); // here's the part I don't know... how to connect the inout interface ports to the inout ports of this Verilog wrapper module? [B] //????? how to handle inout signals???? assign ddr4_bus.DQ = DQ; assign DQ = ddr4_bus.DQ; //????? how to handle inout signals???? assign ddr4_bus.DQS_t = DQS_t; assign DQS_t = ddr4_bus.DQS_t; //????? how to handle inout signals???? assign ddr4_bus.DQS_c = DQS_c; assign DQS_c = ddr4_bus.DQS_c;[/B] // pure input signals are a piece of cake... assign ddr4_bus.CK = CK; assign ddr4_bus.ACT_n = ACT_n; assign ddr4_bus.RAS_n_A16 = RAS_n_A16; assign ddr4_bus.CAS_n_A15 = CAS_n_A15; assign ddr4_bus.WE_n_A14 = WE_n_A14; assign ddr4_bus.ALERT_n = ALERT_n; assign ddr4_bus.PARITY = PARITY; assign ddr4_bus.RESET_n = RESET_n; assign ddr4_bus.TEN = TEN; assign ddr4_bus.CS_n = CS_n; assign ddr4_bus.CKE = CKE; assign ddr4_bus.ODT = ODT; assign ddr4_bus.C = C; assign ddr4_bus.BG = BG; assign ddr4_bus.BA = BA; assign ddr4_bus.ADDR = ADDR; assign ddr4_bus.ADDR_17 = ADDR_17; assign ddr4_bus.DM_n = DM_n; assign ddr4_bus.ZQ = ZQ; assign ddr4_bus.PWR = PWR; assign ddr4_bus.VREF_CA = VREF_CA; assign ddr4_bus.VREF_DQ = VREF_DQ; endmodule;
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 interface DDR4_if #(parameter CONFIGURED_DQ_BITS = 8) (); import arch_package::*; parameter CONFIGURED_DQS_BITS = (16 == CONFIGURED_DQ_BITS) ? 2 : 1; parameter CONFIGURED_DM_BITS = (16 == CONFIGURED_DQ_BITS) ? 2 : 1; logic[1:0] CK; // CK[0]==CK_c CK[1]==CK_t logic ACT_n; logic RAS_n_A16; logic CAS_n_A15; logic WE_n_A14; logic ALERT_n; logic PARITY; logic RESET_n; logic TEN; logic CS_n; logic CKE; logic ODT; logic[MAX_RANK_BITS-1:0] C; logic[MAX_BANK_GROUP_BITS-1:0] BG; logic[MAX_BANK_BITS-1:0] BA; logic[13:0] ADDR; logic ADDR_17; wire[CONFIGURED_DM_BITS-1:0] DM_n; wire[CONFIGURED_DQ_BITS-1:0] DQ; wire[CONFIGURED_DQS_BITS-1:0] DQS_t; wire[CONFIGURED_DQS_BITS-1:0] DQS_c; logic ZQ; logic PWR; logic VREF_CA; logic VREF_DQ; endinterface
