Creating tasks in Embedded Linux
gowthamn
Member level 3
Member level 3
Hi All,
I have been working in writing linux kernel and never worked on writing applications. I am required to develop application which reads file from USB drive and copies the data into Flash memory.
The design approach was to have multitasking.
I am not well versed in creating tasks in embedded linux, can you give some inputs how to start multitasking in linux, also some examples if available so that i can start my development.
Hello Gowthamn,
Please let us know the name of the embedded linux you are using. Is it uclinux? Does it have mmu support or not? We will usually create process for multitasking which u can do via fork.
Hi All,
Does Your Embedded linux supports applications? If yes then you can write an application. If you can write an application and execute on your Embedded Linux then You can create a task. then If your Embedded Linux kernel Has a fork() system call then you can create new processes from within your application. If your Root FS has libpthread and corresponding Header files then you can even write multi threaded application.
regarding examples
try some printf(" dsfhgdsakjfghsak\n");
fork();
fork();
see if it prints and why it prints.
enjoy.
