Creating PSD Plot for random signal.
rg21
Newbie level 2
Newbie level 2
Hi,:smile:
I have to create a psd plot. As of now, i don't have any input signal or known function to base my input upon.:sad: Although i will get them after two months.:-DThe only thing known to me is the range the input values should lie between.
So i thought of generating random values in that range and use them as my input.
I need help with the procedure to be followed and any other functions i could use in this regard.
Thank you for the reply
Hi rg21,
Have a look at the statistical signal processing toolbox of Matlab in the following link:
It contains many methods for PSD calculation.
Best regards.
Reactions: rg21
    rg21
Hi,:smile:
Use this function in matlab periodogram
Reactions: rg21
    rg21
Generate a stream of random numbers, calculate their autocorrelation function using autocorr then calculate its FFT.
