Creating PCB footprint from datasheets in ORCAD layout
subharpe
Full Member level 4
Full Member level 4
Bangalore,India
Can someone give me some link about Layout design tutorial in ORCAD? I am using ORCAD for schematic and Layout Plus for PCB layout. I went through the in-built Layout Plus manual but it didn't seem satisfactory. Can someone help?
Thnx in advans.
Re: ORCAD Layout
Hi ru created netlist from the orcad capture..
after that u can map the link to the orcad layout.. thats all...
if u need call me to my mobile no..
91 9841265124
Malachi Devanbu S.
ORCAD Layout
1-you can use getting start with orcad llayout in pdf format. these file located in the doc folder of installation pass of orcad.
2- go to help bottom and run toturial in multi media vision.
3- if you have a special question plz reply to explain
Re: ORCAD Layout
Hi, thnx to all replied. What specifically I want is to crrate the PCB footprint of a few devices from their datasheet. Can someone help me out?
Re: ORCAD Layout
subharpe said:
What specifically I want is to create the OrCAD PCB footprint of a few devices from their datasheet. Can someone help me out?
Go to this group: **broken link removed**
There are links to tutorials (the links are public, it's not necessary to join to see them).
There are also tutorials in the files.
Also check the archives (they are also public), because your questions did come up in the past.
    subharpe
