creating footpring according to rf connector datasheet 32K243-40ML5
yefj
Advanced Member level 5
Hello,I need to create three pads to accomidate the RF conector.
two pads fro the crews and one pad for the inner RF pin.
few questions.
1. how can I know to which board width this component can handle?
2.according to the datasheet what is the inner pin pad width and length I should use?
3.I want the crews to be in tight fit so the connector woulg be stable in the board.
What pad diameter I should use?
Thanks.
https://products.rosenberger.com/_ocassets/db/32K243-40ML5.pdf
Manufacturer is proving a footprint drawing https://products.rosenberger.com/_ocassets/mb/MB_208.pdf
PCB design with correct transmission line transition, topology and impedance is however your job.
I remember that you have asked about mounting of similar connectors in previous threads. While Rosenberger seems to offer only a single connector of this type, other manufacturers have a larger portfolio, probably fitting a larger range of PCB configurations. I believe they also provided more detailed mounting instructions.
LaTeX Commands Quick-Menu:
