LeeHavens
Newbie level 5
Hello,
Can anyone help me with this error? I have replace the part, changed the footprint, and most of the basic things I could think to do to fix this error. I am a new PCB Designer and need a little help, I am struggling to understand what I am doing wrong. I would appreciate any help I can get to fix this netlisting errors.
Sample output:
#1 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '1N5817 {RefDes D1}' for device 'DIODE_1N5817_1N5817' not found in PSMPATH or must be "dbdoctor"ed.
Symbol extents are greater than the drawing extents ... increase the drawing extents.
#2 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '73725_0110BLF {RefDes J1}' for device 'FCI 73725-0110BLF_73725_0110BLF' not found in PSMPATH or must be "dbdoctor"ed.
#3 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-337): Unable to load symbol '3PIN_MOLEX_CONNECTOR {RefDes J12}' for device 'MOLEX 3 POS 22-23-2031_3PIN_MOL': WARNING(SPMHUT-127): Could not find padstack 082SQ041P. [help]
#4 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '5PIN_MOLEX_CONNECTOR {RefDes J14}' for device 'MOLEX 5 POS 22-04-5052_5PIN_MOL' not found in PSMPATH or must be "dbdoctor"ed.
#5 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'SM02B-BHSS-1-TB {RefDes J20}' for device 'JST 2 POS SM02B-BHSS-1-TB_0_SM0' not found in PSMPATH or must be "dbdoctor"ed.
#6 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-337): Unable to load symbol '2PIN_MOLEX_CONNECTOR {RefDes J23}' for device 'MOLEX 2 POS 22-23-2021_2PIN_MOL': WARNING(SPMHUT-127): Could not find padstack 082SQ041P. [help]
#7 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '6PINMOLEXCONNECTOR {RefDes J25}' for device 'MOLEX 6 POS 26-60-4060_6PINMOLE' not found in PSMPATH or must be "dbdoctor"ed.
#8 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '5PIN_MOLEX_CONNECTOR {RefDes J29}' for device 'MOLEX5PINHDR_5PIN_MOLEX_CONNECT' not found in PSMPATH or must be "dbdoctor"ed.
#9 ERROR(SPMHNI-191): Device/Symbol check error detected„;Â’ôÕœWN¼
WARNING(SPMHNI-194): Symbol '4PIN_MOLEX_CONNECTOR {RefDes J33}' for device 'MOLEX 4 POS 22-23-2041_4PIN_MOL' not found in PSMPATH or must be "dbdoctor"ed.
#10 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'DB9FEMRECPT {RefDes J38}' for device 'DB9_0_DB9FEMRECPT_DDB9FEMRECPTB' not found in PSMPATH or must be "dbdoctor"ed.
#11 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'DB9FEMRECPT {RefDes J39}' for device 'DB9_DB9FEMRECPT_DB9FEMRECPTDB9' not found in PSMPATH or must be "dbdoctor"ed.
#12 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'DB25_FEMALERECPTACLE {RefDes J40}' for device 'DB25_A_DB25_FEMALERECPTACLE_DB2' not found in PSMPATH or must be "dbdoctor"ed.
#13 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'DB25_FEMALERECPTACLE {RefDes J43}' for device 'DB25_DB25_FEMALERECPTACLE_DB25' not found in PSMPATH or must be "dbdoctor"ed.
#14 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '24AWG {RefDes J46}' for device '24CP_24AWG_24AWG' not found in PSMPATH or must be "dbdoctor"ed.
#15 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-337): Unable to load symbol '3PIN_MOLEX_CONNECTOR {RefDes J48}' for device 'MOLEX 3 POS 22-23-2031_3PIN_M_1': WARNING(SPMHUT-127): Could not find padstack 082SQ041P. [help]
#16 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'DF1920P1V {RefDes J5}' for device 'HIROSE DF19-20P-1V_DF1920P1V_DF' not found in PSMPATH or must be "dbdoctor"ed.
#17 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '2923041_USB_RECPT {RefDes J8}' for device 'USB-B_2923041_USB_RECPT_2923041' not found in PSMPATH or must be "dbdoctor"ed.
#18 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'MOLEX5PINHDR {RefDes JA1}' for device 'MOLEX5PINHDR_MOLEX5PINHDR_MOLEX' not found in PSMPATH or must be "dbdoctor"ed.
#19 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '5PINMC {RefDes JA2}' for device 'MOLEX 5 POS 22-04-5052_0_5PINMC' not found in PSMPATH or must be "dbdoctor"ed.
#20 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '6PINMOLEXCONNECTOR {RefDes JA25}' for device 'P1_10PIN2ROW_HDR_6PINMOLEXCONN' not found in PSMPATH or must be "dbdoctor"ed.
#21 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'P1_10PIN2ROW_HDR {RefDes JA29_JA20}' for device 'MOLEX 2_0_P1_10PIN2ROW_HDR_MOLE' not found in PSMPATH or must be "dbdoctor"ed.
#22 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'DB9FEMRECPT {RefDes JA4}' for device 'DB9_DB9FEMRECPT_DB9FEMRECPT' not found in PSMPATH or must be "dbdoctor"ed.
#23 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'P1_20PIN2ROW_MOLEX_HDR {RefDes JA5}' for device 'MOLEX 2_54MM 20 POS 0022552201_' not found in PSMPATH or must be "dbdoctor"ed.
Symbol extents are greater than the draw„;Â’ôÕœWN¼
#24 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '5PIN_MOLEX_CONNECTOR {RefDes JA8}' for device 'MOLEX5PINHDR_5PIN_MOLEX_CONNE_1' not found in PSMPATH or must be "dbdoctor"ed.
#25 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '117210814 {RefDes K1}' for device 'RELAY_TE_CONNECTIVITY_24V SPST_' not found in PSMPATH or must be "dbdoctor"ed.
#26 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol '24AWG {RefDes T1}' for device '24CP_24AWG_24CP' not found in PSMPATH or must be "dbdoctor"ed.
#27 ERROR(SPMHNI-191): Device/Symbol check error detected.
WARNING(SPMHNI-194): Symbol 'DG306B {RefDes U2}' for device 'DG306B_DG306B_DG306B' not found in PSMPATH or must be "dbdoctor"ed.
------ Library Paths ------
MODULEPATH = .
C:/Cadence/SPB_16.6/share/local/pcb/modules
PSMPATH = .
Library
P:/Everyone/Engineering/Library/OrCAD_Lib/Footprints/
P:/Everyone/Engineering/Library/OrCAD_Lib/Pads/
C:/CADENCE/SPB_16.6/tools/capture/library/
PADPATH = .
Library
------ Summary Statistics ------
#28 Run stopped because errors were detected
netrev run on Jun 10 8:48:13 2013
DESIGN NAME : 'GV30XX_TEST_FIXTURE'
PACKAGING ON Mar 11 2013 16:26:28
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
28 errors detected
No oversight detected
No warning detected
cpu time 0:02:29
elapsed time 0:00:01
INFO(ORCAP-32005): *** Done ***
Thank you,
Lee
Sample output:
MODULEPATH = .
PSMPATH = .
Library
PADPATH = .
Library
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
28 errors detected
No warning detected
cpu time 0:02:29
Thank you,
Lee
