Creating a Databse in Development Board Memory
baduR
In my project I'm using Beagle Board Xm Rev B. There it has 2Gb NAND x 16 (256MB) and 2Gb MDDR SDRAM x32 (256MB @ 166MHz). What I need is to create a database inside the memory. How can I do this. Please help me on this..Thank You all.
Re: Final Year Project_Using Development board
depending on complexity you can write you own data structures in memory with functions to store, lookup and read information or use an in memory database, e.g.
Reactions: baduR
    baduR
Hi
A simple data base can based on a data structure(a union housed structure in c language) with ptr access to it's components.
The structure can be placed in ROM{FLASH} and need to copied to ram using an image structure, up on Reset.
you can also use a more sophisticated method like "linked-list" and sorting algorithm - but this is the basic and most simple type
I use this method in allmost all micro controller project I design.
All the best
Bobi
