Creating a custom command shell using perl
rickyice
Junior Member level 2
Hi I need to create a simple command shell in Perl, however I am throughly stumped on where to begin. I would like to encorporate some basic sh files into it. Any suggestions on where to start???
Anything you could give me would help
Thanks
every perl script is cmd, just put this on very first line...
#!/usr/bin/perl
then on shell, write this cmd
(> is shell prompt)
> chmod +x script_name
and "encorporate" existing sh files in script:
use "system" (if you donot want shell script output in Perl)
or use `` (backquotes, if you want shell script output in Perl)
system("script1.sh"); #shell output not required
$var = `script2.sh`; #shell output required
